ACT
Results 1 to 2 of 2
Thread: T25 5-speed gearbox -3H code
  1. #1
    Forum Only Member I should join the club
    Join Date
    Mar 2007
    Location
    tipperary
    Posts
    130
    Default T25 5-speed gearbox -3H code
    t25 5 speed gearbox from T25 1.6 JX turbo diesel Panelvan.
    code - 3H 13 020
    http://www.brick-yard.co.uk/VehicleS...3/info/gbx.htm
    No shift arm, and Will be sold without bellhousing. Rear mount bracket there, and clutch arm, slave cylinder and bracket, cut shafts with inner CVs included.
    Pulled from running van (not by me) -was told 'it was good' by the seller, but I cant personally 'guarantee' the box..
    Hence - €220.
    Now €180 as I need the space!!
    Kevin -086 059 3350
  2. #2
    Join Date
    Mar 2007
    Location
    tipperary
    Posts
    130
    Default
    provisionally sold.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered byvBSocial.com and Block Facebook
